Hello!
Can anyone recommend a foolproof way of transferring FLAC files to the Xperia 1?
PC Companion leaves out files from folders even though they are obviously there
Why do only 4 files out of 6 in the folder concerned transfer to the Xperia?
Forget Pc Companion, and either just connect with usb to pc, and drag and drop, or use something like wifi file explorer, and do it wirelessly.
Oh and if you have anything that is precious for you like photos or other files then store it on a SD card.
It can be taken out and transfered to PC, other smartphone or whatever at any time.
Even when you forget your phone's unlock code your precious files will always be within reach.
Better safe than sorry.
PS
And even then: make a backup every now and then.
Thank you.
I have tried drag and drop but it still does not transfer the whole folder.
Tracks are missing.
Have you tried a different USB Cable?
The USB Cable could be faulty
