I'm having a 'stuck' alarm notification at the top of the screen next to the battery symbol.
No set alarms and never set this one previously.
Already tried the usual...
Any help?
Thanks
Interesting...
When I set a new alarm, the notification is on the far left with the stuck one on the right... Odd
Read my previous post again..
Oophs, only saw the first line as reading through email...
Previously looked at all of what you suggest... couldn't find an App or anything...
But thanks anyway
It's definitely an app, a third-party app to be precise (non-Sony or Google). A software repair would fix this provided that you restore your apps gradually and monitoring the icon if it appears again when a certain app is re-installed.
I didn't see in your comments if this "alarm" actually shoots on Sundays 8 AM or not?
Yeah, defintely an app, which was not on the phone when you bought it, that has set a timer/notification/system change for that time.
You need to go through them 1 by 1 if you can and uninstall/re-install to check them.
Or go the full hog and reset the system.
