My Xperia 1 will not start easily and the touch screen does not function, so I can't get into my phone. Is there any way of getting it to work? If not, how do I get in touch with the warranty department? Thanks.
If it does not start properly:
Perhaps a factory reset or softwair repair via PC Companion is something to try before sending it in?
If it hangs/non responsive:
Long press the power key and the volume up key at the same time until your device vibrates.
Depending on whether you wish to force the device to restart or shut down, proceed as follows.
