Dear Community,
i have the Xperia 1 IV since 4 months. I've had a problem with the Side Sense-settings since the beginning:
The selected apps in the Side Sense-menu disappear again after a while (some days, some weeks) and some other random apps appear. Apparently this occurs for no particular reason. And that has nothing to do with a reboot: after reboot the selected apps are still there.
The phone is up to date (all latest updates), Android 13, build 64.1.A.0.891
Grateful for any help from you,
regards Tony
Hey,
I guess there's a system app for the side sense feature on the phone, try to clear cache and data and force stop it, and check its performance again.
