Hi there,
After upgrading to Android 10, the colors got more saturated. After a while, the colors went back to their original appearance. However, I enjoyed more the saturated colors. Is there a way to bring them.back?
Thank you very much
Try settings->display options
It doesn't work. Any other solutions?
The oversaturated color is a bug where the color management system (CMS) doesn't initialize properly.
The closest you can get to this is to switch from Creator mode to Standard mode (Settings>Display>Image quality settings). It won't give as intense color saturation as when the CMS fails though.
Looks like if you restart the phone from time to time, the saturated colors come back. This 4K OLED display with these saturated colors is the BEST !!! I hope Sony will keeo them.
The closest you can get to this is to switch from Creator mode to Standard mode (Settings>Display>Image quality settings). It won't give as intense color saturation as when the CMS fails though official myprepaidcenter
