Hi all,
After last update I noticed that whwn you perform the gesture with scroll down once to see first partnof notification bar then all the information / icons like wifi, battery level % etc. are going down too. I mean it is moved and shown lower as indicated below:
As you can see time remains unchanged. When it was before.
Now if I will scroll this list once more down to expand entire notificaion list then all these information like wifi icon, batterly level % etc is completely gone!:
Is this a bug?
Can someone eith previous firmware version confirm if this was the same???
Why there is no any changelog???
Why sony old management is soo stubborn?
This is soo annoying 😕
I still have android 9 and the icons look the same as yours.
Android 10 will probably never fly to the Ukraine region.
