Right I think that stability has not improved one iota, though gratefully and admittedly there have been a host of other fixes,
Anyway dont let me influence you, i have undertaken some tests for you to judge yourselves.
NORMAL APP 4K NO HDR BUT H265 Stability ON
https://www.youtube.com/watch?v=BmQTf6wDAs0
Normal app 4K NO HDR But H265 Stability OFF
https://www.youtube.com/watch?v=0YHET2NC5k8
(STABILITY LOOKS BETTER) you decide though.
CINEMA PRO HDR ON H.265 Stability ON 4K NO LUT and 24 FPS
https://www.youtube.com/watch?v=zOCq9IY2jlA
CINEMA PRO HDR ON H.265 Stability ON 4K NO LUT and 30 FPS
https://www.youtube.com/watch?v=lzzfH6u0qVM
(still being processed by youtube, so waiting for video quality to improve)
What do you all think, you decide?
Based on the update log, they did not improve this at all.Only Camera improvent it's image processing now from 7 seconds change to 4 seconds
I agree, image processing for me is around 1 second
OK. I have found out the stability issues affect even 1080p, but only when HDR is on!
WHen HDR is off, all is OK.
@GilgameshUK wrote:I agree, image processing for me is around 1 second
@GilgameshUK
What setting are you useing? HongKong Fw and China Fw all are around 4 second after update,sometime about 1/20 chance to have 1 second.
Just general settins that one would normally use
Again you decide on what you feel is the best, I will just provide testing links I conducted earlier today.
NORMAL APP TESING AT 1080P HDR OFF Stability ON
https://www.youtube.com/watch?v=QZ-nV4aOmQs
NORMAL APP TESING AT 1080P HDR OFF Stability OFF
https://www.youtube.com/watch?v=kgu7Zu-Wrl4
NORMAL APP TESING AT 1080P HDR ON Stability ON
https://www.youtube.com/watch?v=YVeuZiWO4ro
NORMAL APP TESING AT 1080P HDR ON Stability OFF
https://www.youtube.com/watch?v=i3TwPmBhE50
HOPE THAT GIVES YOU ALL A BIT MORE INSIGHT!
Now judging by my tests we have a new spanner in the works.
Not only do we have a problem with stability in 4k but there is an issue in 1080p.also.
If I enable HDR in 1080p then the video is LESS stable than 1080p with HDR OFF.
So to sum up work needs to be undertaken on 1080p HDR stabilisation.
All is fine on regular 1080p
That'll be you on the mail trail again, to Sony Mobile then...
Buwahaha nah
Better just to test and leave here.
Fed up of dealing with telephone support and their scripted replies
