xperia 1
i have a movie in 4K format
however , when i open it with the built-in video software , sound cannot be played . The audio coding is DD+.
when i use a third-party player (like "kodi"), it cannot turn on the 4K mode
so,how can i watch the 4k movie in 4k mode
If the audio track is not compatible then your best bet is a video converter tool which allows transcoding of the audio only, rather than the video as well because doing the latter can be extremely time consuming. I'm on a Mac and use Smart Converter Pro.
That said, all the 4k movies I have tried have played perfectly. Whether you could tell the difference between 4k and 1080p however, is a moot point.
