You're enjoying your beautiful shiny Xperia smartphone and suddenly it has some hickups.
Let me explain a bit and help you overcome most common problems.
Most problems are caused by apps you installed on your device.
How come.
Not all apps are constructed like it should. Those apps aren't very good at allocating memory and after some time those apps make a mess of your phones memory.
Tip
Should you still encounter problems then your first resource is the Support App on your device.
It offers a wealth of information, usefull tips, tests and contact information to Sony Support Service in your own region.
If you want to tackle the problems yourself the first step is to check if the mishap happens in Safe Mode too. In Safe Mode the device starts up with only the preinstalled systems apps running. Disturbance from self installed apps is eliminated.
Tip
When your device is irresponsive, in a boot loop, has a dark screen or acting weird otherwise you can force a restart by pushing Power button and Volume Up together and holding it until the unit vibrates.
After that you can restart.
When there is a problem you can start testing, finding out which app causes the problem and keep yourself busy deleting the last installed apps.
Often this helps.
Example:
Better eliminate all problems.
The easiest and most successfull way is by doing a Factory Reset (you can find that in settings)
or even better a Software Repair with Xperia Companion.
Before you do a Factory Reset or a Software Repair you should save your data.
TIP
Enjoy!
