Is there a dark mode available?
Dark Theme under Settings-Display-Advanced.
Hi @Alieninfiltration,
Just as @RuneJ mentioned there is a dark mode in the Xperia 1, but it is only available after updating to Android 10, so if you are still on Android 9.0, you will have to wait a bit longer for the update to be available and after that you can enjoy the dark mode!
edit: In Android 9.0 you have something called dark theme, but this does not turn everything dark (settings menu and so forth) like it does in Android 10.
@Alieninfiltration wrote:Is there a dark mode available?
In Android 9 or even 8 (or maybe less) :
There are some apps supported dark mode
- Some of Sony.....apps like ( Music / Album / Support )
- Many of Google apps like ( Messages / Calender / Clock / calculator / Keep Notes...etc )
- 3rd apps same things like ( Twitter / Instagram / Telegram / Samsung Internet / XDA app / Outlook / ....Etc. )
WhatsApp currently under development
In the setting of app/apps you will find an option.
This is excellent apps to enable the dark mode for some apps like ( Google Play Store / Instagram...etc.)
https://play.google.com/store/apps/details?id=systems.maju.darkmode
It's working fine with my Z2 and Z2 Tablet with Android 6.0.1
In Android 10
In Settings > Display > Dark mode
@alaa_buhussaien, that is very true!
Almost half the application that I use only a delay basis only have a dark mode option now, even on earlier Android versions than 10.
Feels a bit strange that there is no option to turn it off though in most applications in case you don't like it, but most people seem to prefer a dark mode.
