can i use normal usb type c to charge xperia 1 battery?
Hi @drlmiles, thank you so much for doing this test!
I'm really glad to see that PD is so much faster than Qualcomm Quick Charge, even if I knew it was going to be faster, almost 40-45% faster is a big upgrade in charging speed and even if you forgot to charge your and it has 0% in the morning, it will be almost 20-25% when you are done brushing your teeth and having a shower so the morning commute is saved.
The best part about PD as I mentioned in my previous post is that it's more of a general industry standard and hopefully more and more devices will support PD charging in the future.
@SAWIG, thank you so much for the information and yeah, PD is more of a standard just like Qi (wireless charging) and as long as the device supports it, it doesn't really matter which charger you use, as long as it's a PD charger.
Previously it was like a specific USB cable for the UCH10/UCH12 and it was quite hard to get a hold of it again if you lost it and having to carry around different cables/chargers is just an annoyance.
Thanks again for all the information!
