Hello
Since last, android update , i cant Turn off the sounds of buttons.
How can i turn off the sounds, because in settings icant.
Thanks
@kochab can you post a screenshot from settings - sound - advanced? There you should be able to find the options for different sounds.
https://www-support-downloads.sonymobile.com/j8110/userguide_AE_J8110-J8170-J9110_2_Android10.pdf
