Has anyone else experienced issues with the mobile banking app force closing,during the registration process? Continuously happening, which results in a lockout from the registration process,which is very frustrating!
Go play.google.com where you can find the ones that issues this app.
Mail them and ask.
Test on your device.
Take out SD and SIM and see if it will install using WiFi
Try reinstalling
Try calling the app managers on a hot line. I hope they’ll help you. However, sometimes such issues appear on old devices, so I suggest you consider that aspect. I’ve been having issues with my budget calculating program
