The apps that are not optimized for ultrawide screen is on top of the screen.Can I make it in the center?Or plz make it an option in the update.I feel terrible playing some games.
BTW I find it better if I enable notch in Developer options...But I have to change that every time I play.
Hi @SWERecker, welcome to our community!
It is not possible to avoid this by changing the display settings on the device.
Currently, some apps are able to fit 16:9 full-screen content on part of a 21:9 display. Others stretch this content to fit the vertical dimensions of the display, resulting in unwanted cropping on the sides. In some apps it is possible to switch between these modes, in others it is not possible.
To my understanding, the apps will need to be updated to fully support 21:9 so hopefully that will be done and you can always find the contact information for the app developer in the Google Play store!
