Hello,
since last update I noticed that when you are using gesture to see recently opened apps and switch between them there is no longer the horizontal stripe and no possibility to move your finger left to right (and vice versa) that innpast was allowing the fast selection between all open apps, even if you had plenty of it.
It was possible to do this with one gesture when you constantly were touching the screen.
This option is gone.
Now you have to perform 2 gestures, first to slide up to see all open apps, untouch the screen and then second gesture to switch betweeen apps and click the one you want to open...
Why previous possibility was removed?
Why degrading the software?
