I have just updated to Android 11 on my Xperia 1 this morning, and the biggest problem I have is that the side sense bars are showing up on the screen whenever I switch apps. Transparency is set to high so it shouldn't be showing at all. If it stays like this I will probably have to turn it off.
Has anyone found or know of a fix for this?
Try to check this link, it has all the instructions of the side sense on the device, it might help: https://www.sony.co.uk/electronics/support/mobile-phones-tablets/articles/SX676901
