Using v2.00 firmware.
If l set the resolution to 21MB (APS-C cropped) and save it to Camera set.memory if changes to 50MB (FULL FRAME) on recall.
And if l set the camera to 21MB crop and switch the camera off and on it goes to 50MB full, a bit frustrating.
I don't think it did this with the old firmware.
Hey @GordonT
You can try updating to v. 2.01 and check if it fixes this issue. It has been just released, a few days ago.
https://www.sony.co.uk/electronics/support/e-mount-body-ilce-1-series/ilce-1
Using v2.01, no change
Do you have an A1 to try it on ?
Here's the sequence, showing saving at 21MB, recalling at 50MB...
